Does any one have the parts list.
I know i need.
1.tranny 5speed
2.engine harnes
3.Ecu
4.of course an 02-05 eco 2.2+accessories
5.Ecotec upper motor mount
I have read about the swap for the 2200 form factor but have not found swap info the 2.4L.
Mine is already a 5 spd.
Yes it is going in my 02 4 door Z.
Thank you for any information.
I'll hopefully be doing this swap soon too.
what I can add to your list is:
Eco radiator
Eco radiator hoses
I believe the alternator and A/C bolt up okay. I know there's some issues with the fuel lines, but I'm not quite sure what the fix for it is.
Desert Tuners
Radiator i thought was the same as the 2.4 the altinator i know is different And i believe the fuel line issues were the 2200s due to were the placement of the fuel rail
The Radiators are different. For the fuel lines you only need the part that connects to the fuel rail to the hardline under the car. You will need a Ecotec A/C compressor and the lines that connect directly to the compressor. Truly the swap from a 2.4, or a 2200 to a Ecotec is no different. Since your car is already a 2000+ you have it easy.
Here is a picture of the fuel lines (all of them), you only need the black part.
gotta use the eco alt and a/c
its pretty much the same swap as doing it from the 2200
yeah i thought it was compairable to the 2200 other than the intake exhaust the same in location so i thought it would be a slightly diffrent needs. Thanks for the info anyone have any more nessicties.
Your tranny will work, but you need to swap the bellhousing so it will bolt to the eco, otherwise it's identical.
Um most front wheel drive cars do not have removable bell housings this includes ours. identical inside yes but front wheel drive and removable bellhousings are not common in this time and age.
keep us updated Nightmares. I should be starting to buy parts in about 2 weeks.
Desert Tuners
NightmaresCavy wrote:Um most front wheel drive cars do not have removable bell housings this includes ours. identical inside yes but front wheel drive and removable bellhousings are not common in this time and age.
Getrag's have removable bellhousings, the older Isuzu's didn't.
ok now i'm f"in confused do you have pictures?That would be so nice
Ian Brydon wrote:NightmaresCavy wrote:Um most front wheel drive cars do not have removable bell housings this includes ours. identical inside yes but front wheel drive and removable bellhousings are not common in this time and age.
ether 1 of those is relevant , and missinformation
the isuzu and getrags have a fixed belhousing/case , you have to change the belhousing/case half to swap it
at which point , you would have had to buy another trans
just get the whole eco getrag , and youll have far less money and time invested
Edited 1 time(s). Last edited Tuesday, August 22, 2006 3:32 PM
Ha i win i was right HEHE thank you for the info
sounds like I'll keep you posted then. LOL
Desert Tuners
Thanks keep me updated so i can make this swape go as quickly as possible. I would have already started getting parts but i had to get a new motor for the wifes car. And now my computer at home is glitching so if have to rebuild it more money i had plans for. Damnit oh well i have time i told me wife i wouldn't put the new motor in till it hit 130kmiles i'm at 84,000 now. The wifey gunna start helpin me buy parts soon.
I have been set back again another 500 i could have spent to the swap now has go to deductable. last night i got in an accident.
