best bet would be to measure youre longest stocker, and get enough universal to make your own.
I'm thinking 25ft would be plenty, just make sure you get the proper connectors for the coilpack side. (short 90 degree elbows)
you can bolt the msd coils on the stock coil interface if you want untill you hook up ur dis-2, then you will need the coil interface adaptors, and why dont you go half and half on a universal 8V wire kit and split it with someone?
Correct. You need 2 of PN8224
Cavie Freak wrote:Kardain wrote:Quote:
Aren't they sold as a set of 2? Everywhere I see them they say includes 2. Now with that v8 kit which one do I need though?
The coils you can get seperately, not just in pairs.... I've never really seen them in pairs aside from TTR.
as far as to which universal v8 wires to get, just make sure they have 90 dergree boots on one side and 180 boots on the other and ur set. you will however need to get a crimper tool to put the connectors on the ends of the wires once you cut themm for length.
Are you in morris right now?
yes straight up if you want to run just the coils get 2 and they bolt up right to the stock location very quick....id sugest getting taylor wires since they are already made for our application. If your going to run dis2 you have to use the coil adapters..phil
Cavie Freak wrote:Ok so msd doesn't make a exact fit kit for our cars. I am wondering on this page of universals wires what is the one that will work with my engine. I am also wondering if I can get the coil packs and just bolt them in With out the adapter for the dis-2. I don't plan on running the dis-2 till later on just wanting to get these for now. Thanks
http://www.msdignition.com/wire_3.htm
If your interested I could go in halves with you for a set of wires. I work at Autozone and get 20 percent off. We have v-8 sets with the 90 degree boots from MSD. They are 8mm. I could prolly get the set of 4 and ship them for $50. IF you interested let me know. I belive these are the ones I'm speaking of
msd wires
Silver Streak wrote:I have the DIS-2 adapters if you would be interested in them hit me up with an email @ I_will_be_right_back@hotmail.com.
I would be willing to part with really cheap
Gunna have to pass on that right now thanks though.
Jucie n' Boost (jucie pushrods wrote:as far as to which universal v8 wires to get, just make sure they have 90 dergree boots on one side and 180 boots on the other and ur set. you will however need to get a crimper tool to put the connectors on the ends of the wires once you cut themm for length.
Nah im back in cali again. Was in morris from dec 15-29th wont be back in that area for a long while now
Philly D wrote:yes straight up if you want to run just the coils get 2 and they bolt up right to the stock location very quick....id sugest getting taylor wires since they are already made for our application. If your going to run dis2 you have to use the coil adapters..phil
Sweet thanks for the info man
purplhaze wrote:Cavie Freak wrote:Ok so msd doesn't make a exact fit kit for our cars. I am wondering on this page of universals wires what is the one that will work with my engine. I am also wondering if I can get the coil packs and just bolt them in With out the adapter for the dis-2. I don't plan on running the dis-2 till later on just wanting to get these for now. Thanks
If your interested I could go in halves with you for a set of wires. I work at Autozone and get 20 percent off. We have v-8 sets with the 90 degree boots from MSD. They are 8mm. I could prolly get the set of 4 and ship them for $50. IF you interested let me know. I belive these are the ones I'm speaking of msd wires
Gunna pass on that one man will have a spare set plus the ones im looking at are only like 70 bux
Edited 1 time(s). Last edited Wednesday, January 10, 2007 10:18 PM
Disclaimer:
Dey see me Trollin' Dey hatin' for trollin dey trying to catch me ridin dirty.
