Is that my old header?
yup sounds like rkcrappy
nice job on doing it yourself
would probably make more sense to have it filled then reground. and if a machine shop couldnt machine it flat, how are you going to get it right? id have TIG'd some metal in there then machined it back down. just my .02
ya i'm goin to have to figure out a way to smooth mine out as well. may look into doin this. thanks.
_______________________________________________________________________
my carDomain updated 11/5/07 I've got premium. Yes I do. I've got premium. How 'bout you?
FAST2.4 P wrote:I would do that but I just need to get the car running.
yeah i hear ya but i dont know how much weaker it would be. looks like a good size flange though to work with
Oh @!#$ I just noticed a big problem. This header has the EGR built in, but my car does not have one. So looking at the header, and the stock gasket, the gasket will overlap the part that is machined out for the EGR an leak gas. I know that i covers it, but there is no bead on that part so there will always be a leak.
http://www.overkillengineeringmotorsports.com/
have it filled and re flattened.
cant you get the EGR block off plate to cover that part up?
1997 Cavalier Z24 - 16.3 in 1320 and falling...
use the stock gasket it blocks the egr port
whitegoose( RedR-ZedR) wrote:cant you get the EGR block off plate to cover that part up?
No need to buy a block off plate. The 00-02 exhaust gasket covers it that is how gm blocks it from the factory.
My bad I did not notcie 97cavie had already mentioned that.
Edited 1 time(s). Last edited Friday, February 15, 2008 8:50 AM
yep, get a 00-02 stock mls gasket... i just bought one yesterday from GM, $28.00. pry get it cheaper from somewhere else tho. its really up to you as to what you would like to do, you can get the block off plate from GM for under $10.00, IIRC mine was $6.00.
wade, so this is the header I sold you? wow... i had no idea the flange was f'd up....
Edited 1 time(s). Last edited Friday, February 15, 2008 9:31 AM
yep I had no idea it was messed up either. I could have sworn it did not leak on my car at least no that I noticed. By the way this header is like the slut it has been in more guys hands than most girls that get called sluts.
^^^ hahaha, to damn funny. But I was thinking that it would leak where the egr part is machined out of the header because the manifold gasket that I have has no EGR, so when I put it up to the manifold, the bead on the port is no longer sealing all the way around it. Does anyone know the orignal owner of this header?
i bought it off somebody on ebay... cant get to the auction cuz that account was canceled
but i had it for like 2 years (and never used it), then wade bought it, now you.
Well I have no leaks and it runs good. One thing though. It is hitting the frame, where the flex joint is. Is there anyway to make something to fit so that it does not rub. The other thing is the crusie control, it wont fit. Right now I have it being held by one bolt, any fix for that? Besides that it sounds rediculas and I bet the HP improvements are good as well. I can post pics if you would like
for the cruize, just re-locate it somewhere in reach of the cable.
The flex joint hitting the frame is a common issue with the header.
Best thing I guess is just to be mindful of road bumps, and parking lot speed bumps.
-M
seriously just get the solid mounts, their pretty cheap so....
So you think that poly mounts would do it? I know all the busings up front need to be replaced, but there has to be some type of fix for this. Its a bad ass header, and the car sounds insane with it.
I had poly mounts the only thing that hit the frame was the body of the universal O2 sensor I used since the stock was not long enough.
