Hey everyone, I race at a local track here in my area in the 4 Cylinder Division... Last night we raced and when I went out to qualify.. I race about 6 laps, then on the front straight away, I had the gas pedal down all the way and I had NOTHING, it started sputtering and sputtered harder and harder by time I got to the back stretch the car stalled on me.... So i ended up coasting into the pits..
At first we just thought we over heated Well when we got the car jacked up and stuff we noticed the outlet hose off the radiator was DRY as a bone, so we added water and finally realized that there was a big Kink in the inlet hose going into the radiator, so we cut some hose off that and got the kink out of it... Figuring we solved the issue...
Well when we went to start the car over to go back out on the racetrack, we had water SPRAYING from the # 4 or # 2 spark plug *if I remember correctly* it was one of the two...
So we are thinking we got water down in the pistons, we blew a head gasket, maybe cracked the head and we are trying to figure what could of been the cause of this or even if we are looking in the right direction in trying to fix it...
Thanks Everyone for the help and advice
Thank you for the advice, I greatly apprciate it...
a temp gauge might help you to keep an eye one things
99redz24 wrote:a temp gauge might help you to keep an eye one things
X2 ..... I thought I had a cooling/overheating problem too. My stock gauge was reading 260+ and my aftermarket on the feed line to the turbo was reading 190-210, so I knew I wasnt actually overheating. I ended up having an air pocket superheating around the stock temperature sender, and it worked itself out after 3-4 days. But it had me stumped for a while!
