Those do not look to be self aligning!
They dont have the tabs on the side of the rollers!
You want ones like these, notice the little alignment tabs on the side of the roller!
1.6 Small Block Chevy Roller Rockers
sorry my bad, i just usually look at pretty pictures.
according to the description, they would work, I second Mad Jack!
DMP wrote:I checked the rocker conversion thread and didnt see them listed. Will these fit? http://www.summitracing.com/parts/CCA-1618-1/
 Let me save you a headache.....This particular rocker will NOT fit.  I was going to use the ProMagnums but they are too wide... They will actually hit the springs.  You need to find a narrow body.
P&P Tuning
420.5whp / 359.8wtq
With all stock components on a 2200, how much is there to gain by simply upgrading to these 1.6's? Basically, is it worth it when you have next to nothing else done (I have an intake and an exhaust w/ header).
"In Oldskool we trust"
well the stock cam lobes would open 1/6 farther I believe. So you would gain a little bit, prob not as much if you were to tune it also.
