hello guys .. im having a problem with my ld9 .. the car just wont idle by itself .. the only way i can turn it on is with my foot on the pedal .. as soon as i take it of revs down and dies .. map seems to read 5 votz and work fine .. and tps too .. iac not quite sure cus i took one from another car .. and worked for a minute then the car died .. so im not sure if is my iac the one causing is or wat
please help
thanks
How long before the car dies once you do get it started?
It could be a fueling issue but won't know unless there's more information to decipher.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
with my foot of the pedal, it just starts then dies .. just last seconds .. but as long as i have the throttle open .. the car stays on
Any check engine light that you may be having?
I had this same issue when my fuel pump went south so this could be your problem but again, not absolutely sure.
If there was a way for you to check your fuel pressure that'd be great.
Also see if you can hear your fuel pump turn on when you turn on the ignition key. It should stay on for about 5 - 10 seconds and shut its self off.
Hopefully someone will chime in that has a bit more experience with this and help.
Misnblu.com
Maintenance Forum
Discussion about general maintenance, maintenance issues, and other normal and not-so-normal j-body issues.
