I cannot find what the little hole on the 2.4 head is that goes to the intake i have read it on here before but cannot seem to find it..Just wondering what it is and whats the use?
bc97cavalier
the EGR?
We all need somebody to believe in something...
PCV,it goes through the head into the block into the crankcase...
        "The FACTS are always subject to CHANGE once the TRUTH is applied"
        "In the entire history of man the only stupid questions are the ones that don't get asked"
Well looking at my gasket it doesnt look like it goes anywhere  just gets sealed off is that correct?
bc97cavalier
Nope,look at the gasket and manifold. Head side of the gasket has a groove that goes up to a small hole going all the way through to the manifold side. Flip the gasket over,the small hole goes into a groove that runs along the top edge from the corner of runner #1 clear over to the top corner of runner #4. Now look at the Manifold. At the top of #2 & 3 runner and the top corner of #1 & 4 there are small notches/grooves cut into the manifold that go into the groove of the gasket. This allows vacuum to be pulled from the crankcase. If your running a turbo it also allows pressure to be forced into the crankcase which is the cause of alot of peoples oil leakage problems...
do you have to have it.?
bc97cavalier
