I have a 1996 cavalier with a 2.2 and 5 speed. I blew a hole in the block so I got a new motor. It came out of a 1997 cavie with a auto. My question is can someone tell me what sencer is what and what do they do? I am not mechanicly stupid just need some guidence.
Old motor
New motor
Any help would be great.
Ill try. Hopefully this is right.
Red= Knock sensor
Blue= crank position sensor
Yellow= oil pressure
White= I dont know lol
2012 numbers - 4SPD
AUTOMATIC!!
so if I dont use the knock senser will my car run funny or would i need a different computer? I dont know what the white one is either. I thought the red one was the oil pressure.
So what do I do if the other motor doesnt have a cam sensor? or the other sensors?
So does anyone have any idea what I should do to make the other motor have those sensors so I can put it in the car?
change the computer or the harness or both
94 cav mini stock
93 cav track bitch
So I cant put those sensors on the block? Cuz I need a quick fix. Worst comes to worse i will find a harness but it mite be hard to find a harness for a 2.2 with only those sensors and a 5 speed trans around where im located.
where exactly would you put them? also, if the engine doesnt have a cam sensor, the cam doesn't have a reluctor for the sensor to sense. you're better off getting a different engine.
Well cant I put a dis into it? It has a hole for one, dont they make them for that engine? Or will that even work?
well that makes sence. Didnt relize that. thanks for the help guys. If anyone else has input let me hear it.
Is that where the Crankshaft Position sensor would be located on my 1997 2.2L Cavi as well?
