Ok now does it matter which ld2 engine you get the exhaust cam from either it be the  the HO or the regular on cause am buy mine new so some help would be greatly appreciated
The HO cam is more aggressive than the LO cam... a true *secret* cam is the LO... however i used an HO exhaust cam with HO housing with no issues...
LO Exhaust CAM = 200 degrees @ .050" with .375" lift
HO Exhaust CAM = 212 degrees @ .050" with .410" lift
Edited 2 time(s). Last edited Thursday, April 22, 2010 10:20 AM
ok what would i need to install with the h.o cams to make them fit correct, because from what i read its not plug and play
you need the 2.3 tower, 35mm lifters and 2.3 spings. I may be missing somethings but thats what I know about. And a tune would be the best way to make more power.
mine are plug and play. there secret cams reground. but id recomend stronger springs and the.050 lash caps.
