So I've been reading on JBO for a few years since I've had my car and I've learned a lot, so thank you JBO for that much. I've also read tons of posts about "I have a 2.2 and I want to go fast for cheap $$$ moneyzz!" which we all know doesn't happen with a 2.2 (ln2, 2200).
The goal I've set for myself is that I would like to reach 15s in the quarter which doesn't seem like much. Now, I don't know how attainable that goal is, that's what I've come to ask. Before I go any further, I'm NOT doing an engine swap, boosting, or spraying my car. If spray is what it takes to get to 15s in the end, then so be it, but I'd rather not.
My profile is up to date. In summary, I have the 3-speed auto, an AEM aluminum CAI, A/C sys. removed, Pacesetter 4-1 header, 2.25" full custom exhaust (resonator, stock BMW 318ti cat, 3A Racing can), 2.3L 56mm throttle body swap, RKSport engine mount, MSCC Subframe Brace, Accel 8mm wires, MSD Coil packs (except they don't do anything w/o "The Box"), NGK plugs, Optima Battery, stripped interior, racing seats and harnesses, and a carbon fiber hood. All I have waiting to be installed right now is a TransGo shift kit and more suspension parts that I could easily get, which will do nothing for power right now.
This whole car has been a cheap used-part budget build and I've seen minor performance gains and the car is much more fun to drive, but I need just a bit more out of it. I need to know how far I can go while still keeping this a budget build.
Will the shift kit actually help anything or will it just give me firmer shifts? Will that really help with quarter times?
What about weight reduction? Is it worth it to strip out the carpeting, the rest of my rear seat, and find a carbon fiber trunk?
I've considered a "stage 1 cam" from J-Body Performance and/or a light valve train build, but that seems beyond my budget for the most part.
I've also considered a port/polish which I've been told has potential to reach high 14s? I can get a head for $75 but the port would be around $1k, near what a cam/valve train build would be so that's too expensive right now. I'm thinking a port/polish might be the way to go though.
After finishing my 56mm throttle body build I've lost some lower end power but gained some higher up. I do mostly freeway driving so it suits me right now, but my quarter times have suffered a little.
Does anyone have any realistic advice for me? I have another project car in storage already with more potential but I want to finish this up so I feel like I've accomplished something. This is my first car and my first real effort at modifying for performance. I'm currently at tech school for automotive/diesel training and am teaching myself ECU tuning on the side but I just started. Anyway, any intelligent advice would be welcomed and appreciated. Thanks.
http://www.cardomain.com/id/Gerkn
I was just thinking, what about a compression increase to 10:1 with WiseCo pistons from J Body Performance?
Bore (mm/Inch) 86.00, Over Sizes 3.386 Std., Stroke 3.724, Comp. Height 1.053, Head cc's, 53.2 FT, Dome/Dish Volume 0CC, Block Ht 8.700., Comp. Ratio 10:1, Pin Diam. .787, Ring Type 8600XX, Gram Weight 276.
Hay, thanks for the reply. If possible, I want to keep this under $1000, but I'm interested in what getting to 15s takes.
Do you think getting the block zero decked, a MLS Head Gasket, and a set of custom pushrods will get me to low 16s at least (I'm running high 16s now)? and I'm confused... You said I can either zero the block with a MLS gasket without resurfacing the head OR zero the block and resurface the head .030" with a stock gasket?
I was looking at your profile, You have tons of experience with machine shops, what are we talking as far as money for the machine work? I know people so I might be able to get some discounts, but what would you say?
As far as the cam goes, what kind of specs do I need to tell the machine shop I want? I'm looking for something mild enough for the street and that I can run as much of the vehicle stock as possible with minor ECU tuning. I'm only trying to reach high-mid 15s and I want my girlfriend to be able to drive the car during her college years (I have another project I can get working on soon for a 2nd car).
I'm not too concerned about taking the engine apart, I can take the car to up north Wisconsin (i live in Illinois) to my grandpa's body shop and take it apart there and maybe get a loaner car for a week until I come back to it.
Sorry about the double-post. Someone from the classifieds is selling a JBP Stage 2 cam and SBI lifters for 70% of retail (Duration @ .050*, Valve Lift INTAKE 207*, 480 EXHAUST 212*, 490) do you think this would be good for my situation to get or too aggressive?
i was going to say underdrive pulley 5hp and roller rockers 1.6? 8hp
Underdrive pulley I've heard isn't worth it for street cars because of the alternator issues. Rockers is a good idea though, cheap and supposedly improves the mid-upper power band. I just need to find a place or person that sells them thats reliable. Can't get the crane ones so I guess I need to find the CompCams rockers... JBP sells them but I keep hearing bad things about them.
Either way rockers and the shift kit should help me out in the quarter a little. Might help make my bored T/B seem like more of a good idea.
I really think you need to look into some moderate port work, at least. You've already opened it up at the throttle body and exhaust; now complement those modifications with a well-flowing head and port-matched intake runners. 1.6 rockers can help but if you're going for a re-grind anyway they're kind of overkill, unless you're looking to get really crazy. After that, the most important thing is a good tune to set it all off an get everything you can out of the modifications you've made. I know this isn't something you'll want to hear, but a good 5-speed may help you out too...
"In Oldskool we trust"
Thanks for the input.
I'm just trying to keep it as cheap as I can while just making into the 15s. Trust me, I'd love to just port the head and be done with it, but it's a very expensive process, otherwise it would be a no- brainer. At this point, if I can't make it to the 15s without spending $1k or more then it's not worth it to me. I bought my car for $1400 and it's lasted me from highschool to college and if it's time to give it up to the girlfriend, then it's time. I have a 1989 Corolla GTS with a 4AGE 5-speed waiting for me to restore so if it can't be done, then it can't be done. I'd like to avoid the regrind if possible and just try getting a set of rockers and see where that puts me without a tune. I'm still learning about ECU tuning stuff in my free time.
if I can leave this car running at 15.5sec, enough to keep up with a 2000 V6 mustang for less than $1000 invested in major performance then I will be more than happy with my cavalier experience.
I'm still open to any ideas, and I'm considering the regrind and ECU tune but I'd still rather not deal with cam tuning.
With an exhaust, ported head, tune, lifters, intake, and motor mounts I was able
To run a 16.3.
Mind you this was on @!#$ty tires and I CAN'T launch the car very well. (5spd). I also had a full interior with a sub and my toolbag (about 50lbs).
The car had more in it, but not with me behind the wheel.
I recommend some headwork as well, but with a tune, this is where
I felt the most improvent. If you search around I guarentee you find a shop to port your head for less than $1000. I found a few places for around $600 by me.
"A car just isn't a car without a little blood, sweat, and beers." -- Shadowfire
Found a set of CompCams Rockers for $95
Summit CompCams
and I'm calling around Milwaukee asking about a port and polish and block zero decking and head resurfacing. Going to pick up a spare head from the junkyard for $75 and see what happens from there. Need to look into custom pushrods...
if you only have a 1000 to spend i think the manual swap is where its at. Bball ran the times your looking for NA with really simular mods. In his profile it says he had a ported head, but I think that was afterwards. I'm sure there are other people on here who may remember a little better. I really think that 3 speed is holding you back though. Check his times and profile in the racing forum top 1/4 times.
I agree on the manual swap. When my car was stock, it would pull away from my brothers 3spd pretty good after 2nd gear.
I bought a used trans for my car when mine popped, and it was only like $300 (50k miles on it). So if you shop around you can probably do the swap for well under $1k.
I believe you, but I'm not really willing to go through THAT much custom fabrication. I can have the car out of commission for maybe 2-4 days max and that's not even certain.
I did however talk to Extreme Speed Cylinder heads over in Milwaukee, Brian built a whole $2500+ OHV sunfire race head for my guy nick back in '04 and he said $275 for a P&P and another $115 for a valve job. I think I'm going to pick a head from the boneyard, send it in for a P&P, get a set of CompCams lifters for $100, then pull a valvebody from an auto at the boneyard and do the shift kit myself and swap it in. That should get me where I want. If not, then it's on to the 10:1 compression and custom pushrods.
Thank god... I was wondering when somebody would mention torque-converters.
Go beyond the "bolt-on".
Nickelin Dimer wrote:Thank god... I was wondering when somebody would mention torque-converters.
Haha. I just never mess with automatics. I can't have enough fun when I'm driving an auto...
wth? are you ppl serious? My Cav, granted about 110k miles in its past, ran a 16.2 at the strip, and all i did was: remove the jack/spare, backseat, and passenger seat... along with some sticky tires, race fuel mixed down in some 93 octane in the tank, balls, and some concentration. 2200 no mods... really. wth are you ppl doing wrong, idk, but i think it may be that you are doing too much. Think Lotus Elise, "Just add lightness." was the philosophy behind that wunderkind auto. So I did just that, sat my lovely g/f in the drivers seat, all of 100 lbs or so (never had the balls then to ask her weight, we'd just gotten started being together), said go when the light goes green... 16.2 no internal mods.
silvercavi02 wrote:wth? are you ppl serious? My Cav, granted about 110k miles in its past, ran a 16.2 at the strip, and all i did was: remove the jack/spare, backseat, and passenger seat... along with some sticky tires, race fuel mixed down in some 93 octane in the tank, balls, and some concentration. 2200 no mods... really. wth are you ppl doing wrong, idk, but i think it may be that you are doing too much. Think Lotus Elise, "Just add lightness." was the philosophy behind that wunderkind auto. So I did just that, sat my lovely g/f in the drivers seat, all of 100 lbs or so (never had the balls then to ask her weight, we'd just gotten started being together), said go when the light goes green... 16.2 no internal mods.
Your profile says that yours was a 5speed manual, not a 3speed auto... DICK.
Long story short, if your going to do internal modifications to your motor, just get another one and build it. But if you want to go cheap... I think my next move would be rockers and a serious tune with serous timing. And some high octane fuel to keep it from detonation.
Yea, I've been getting prices and testing numbers on Desktop Dyno, it looks like some trans work would go pretty far...
I'm looking at a phantom LSD (green $300), Transgo Shift Kit I have already, TranStar GM73CW FA Recon T/C, and some 33/37 sprockets for a 3.06 final drive, and an Alto rebuild kit... can't find prices on the rest and don't really know where to buy the sprockets from...
Otherwise, I'm going to pick up a head from the bone-yard (and maybe have it flow tested just for records) and have it P&P w/ valve job ($390) with the TTR +1mm valves ($100), throw on the 1.6:1 rockers ($100 from summit).
So, quick total for prices that I found plus a $75 head is $965... not including the T/C, sprockets, and Alto master performance kit, and a spare valve body to modify for the shift kit... It will theoretically shave off about 2sec from the quarter putting me at +/- 15sec flat.
I think that's as far as I would like to go. Maybe a Tune. Any more than that and I'll be looking at a cam and have to worry about everything that goes with that (lifters, pushrods, pistons, bottom end work, etc.) so I guess that's the plan over the next 2 years or so. Just need to find prices on the rest of the trans parts and I just have to save up the money.
Already working on ordering an addco rear sway bar, RKsport bushings, and finishing installing the FE2 front bar, so I think I'll be sitting pretty good. Maybe a tie bar or K-Brace in the future if I really get into competition.
My automatic trans class didn't really go into modification other than the valve body so I'm kindof confused. How can you have a 33/37 sprocket setup and have 3 different final drives?? 2.84, 3.06, 3.33.... I thought the drive/driven sprocket and the chain decided your final drive... How would I change from 2.84 to 3.06?
As for the rockers, I was originally looking at this set:
http://www.summitracing.com/parts/CCA-1418-8/ from summit  "COMP Cams Magnum Steel Roller Tip Rocker Arms".
SO instead, I would want to check out the Proform ones and then pick up a set of these ARP studs? (I'll probably get new head bolts, etc. while I'm ordering from them)
"134-7201 M8 X 1.25 base, 3/8" X 24 top, used on '98+ 2200s (some '98s may have M10 X 1.5 holes, check) $72 for 16."
the lemur wrote:if you only have a 1000 to spend i think the manual swap is where its at. Bball ran the times your looking for NA with really simular mods. In his profile it says he had a ported head, but I think that was afterwards. I'm sure there are other people on here who may remember a little better. I really think that 3 speed is holding you back though. Check his times and profile in the racing forum top 1/4 times.
x2 ! 5speed is ALOT better then the 3speed...also IMO stick>auto, dont know your thoughts on that or if you get stuck in traffic alot, i do not so i<3manual
