i cant figure out how to put the rear strut bar on for the life of me theres only one bolt to hook it to the other dousnt have a nut to hold it on what did every one else do
http://www.geocities.com/WIJTuners/?200511
wi jbody site
teamforwardmotion.com has a great how to and has pics
Hey Adam of that post as populated by people that didn't know what they were talking about.
( cutting off the little circle piece
man you just need to get 1 or 2 M8 coarse thread nuts* for each side and bolt down the brackets in addition to the the nut thats already there.( depends on whether you have a bracket with 2 or 3 holes) I recommend putting on the brackets and then putting the bar into place everything should be hand tight. you don't want to over tighten it. it doesn't need it  if you have one the box-end ratcheting wrench is very handy thing to have, as well as a flash light.
* I didn't need longer bolts myself but if you do I believe they are M8 coarse thread.
What I did was replace those two short bolts with longer ones and then the install was cake.
Hope this helps you.
Semper Fi SAINT.  May you rest in peace.
