Hey,
I am thinking of buying these.  Anybody know if they are any good?
KYB - AGX Sport Adjustable Shocks and  Struts
"With its competition grade engineering and construction, AGX® Sport Adjustable Shocks and Struts are perfect for sport enthusiasts and high performance drivers."
Thanks,
Trevor
Anything worth fighting for is worth fighting dirty for.
u are going to get alot of people telling u to read the frequently asked questions section at the top of the page of this forumn
my answer is yes they are good for a drop of around 1.5 inches
I see you already have lowering springs, so I will leave you with this from other forum:
C.T.S wrote:You can't use AGX, any coilovers on KYB's stuff voids the warranty. Coilovers = High Spring Rate.
The 1.5" limitation is just an easy way for them to say no really high spring rates. The actual ride height means nothing, it's the spring rate that makes all the difference. If you're bottoming out all the time that voids warranty too.
If can't remember the numbers but they're around here somewhere, the spring rates that KYB will warranty up to.
Maybe they were 300lb/in front and 250lb/in rear... I don't relly remember.
Sprints will blow and KYB struts. You have to go with Koni's or Tokico D-Specs (not HPs).
