im not concerened about adjustability, im really lookin at quality and affordability. right now i can afford to upgrade my suspension from around 5-$700. i dont really want coilovers but if there are any that come with shox and struts in a full set then im all for it. ive been considering koni reds and yellows but im not sure which to use. the drop im lookin at is 1.5 and no more than 2". wut r u guys' suggestions. also does the koni sport kit need to be modified, i heard u had to bore the strut mounts or somethin like that.. i also need new strut mounts and i have no idea where to get them
you need to read the faqs.
koni reds havent been made for well over a year now, if not longer. first figure out how low you want to drop your car because a 1.5" drop and a 2" drop is a big difference in price change and also figure out if you want coils or springs. you say you dont want coils but if you can find a full setup then you would buy it. i think you need to figure out a little more what you want before we can help
i want springs and around a 1.5 inch drop. i read the faq but all the extra replies kinda throw me off. im lookin for somethin simple but nice. like a complete spring, shock and strut setup
get the eibach prokit (1.4" drop) and kyb agxs which are adjustable and warrentied up to a 1.5" drop. This setup should run you around 550-600 brand new
are the agx's plug n play or do i have to modify them?
Zduece4 wrote:are the agx's plug n play or do i have to modify them?
1) plug and play...
2) option would be koni sport kit
3) also you dont have to read the extra replies, everything you're asking is def in the first post of the FAQ....
[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]get the eibach prokit (1.4" drop) and kyb agxs which are adjustable and warrentied up to a 1.5" drop. This setup should run you around 550-600 brand new
where you finding these prices? Its hard to find AGX's alone for under $500 for the set.
I will buy that exact seupt if I find it in the $5XX range
Darkstars wrote:[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]get the eibach prokit (1.4" drop) and kyb agxs which are adjustable and warrentied up to a 1.5" drop. This setup should run you around 550-600 brand new
agx can be found on ebay for under 400$ shipped, springs 150-200$ shipped.
Funky Bottoms (Event) wrote:Darkstars wrote:[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]get the eibach prokit (1.4" drop) and kyb agxs which are adjustable and warrentied up to a 1.5" drop. This setup should run you around 550-600 brand new
he's right, i found em on ebay.. i guess im gonna go ahead and get them then. thnx for all of the help. is the koni sport kit plug n play also? ive heard that u have to modify them. is that true?
thnx man, i guess ill stick with the agx's i appreciate all the help
