just like the title said i am looking into purchasing the RKsport coilover spring setup. not the whole kit , i am just buying the coilover springs themselves.
i am getting them off of the rksport site for 399,and i am just wanting some info on how you would go about installing them.
Are you installing them on Yellows or D-specs?
Because with the Koni Yellows, you do need to modify the struts too. With the D-specs, the struts are direct replacements.
In the FAQ, there is a walkthough on installing coil overs on Koni Yellows. If you are going with D-specs instead, then skip the parts where you have to modify the strut housing for the Koni inserts.
