are those 95-99 mounts????
cause they dont look familiar to me....2k moutns are super easy
i would say yes they are since they come apart. the 00+ mounts do not come apart
they didnt fit at all in the 00+ mounts so thats why i did it this way... i have the 00+ mounts too ... you got pics of how you did it with them?
The First Twin Charged jbody
blue car (R.I.P) - 240whp @7psi..
silver car - 305whp 315lbs.tq @15psi (91 Octane) or 420whp & 425lbs.TQ @20psi (94 octane+Alcohol Injection)
All dynos run on a Mustang dyno
umm somwhere have to dig around...but the 2k mounts dont have the bearing in the..the bearing is in the boot so i jsut nixed that and but the copper piece straight into the mount...let me see if ican find the pics (assuming i took any)
ahh i ok i got it... i tryed the 95-98 ones and i must be missing a part since it just pulled apart instantly with just the weight of the break.... so i tryed the 00-02 ones again and got them to work much better so far
gravana has all the pics when i sent them how the 00-05 went together
but that looks right for the 95-99 , dont forget the top washer is needed on the 95-99's
my pics might still be up in the other post i linked on the 00-05
both mounts are super simple
also the 00-05 for me made more noise , the bearing holder in the pic rubs the metal lip of the mount , and you need to grind the lip away , then they are fine
so, if you put it together like that, what stops the mount from coming off the top of the strut? i mean, the gravana washer will not hold the strut mount onto the strut. so what does???? got any pics of the toP?
I couldnt figure it out using the 95-99 struts...
farmerz24
the factory uses a large cuped washer on the top , you have to reuse it
or get 1 from a junk yard , since i dont think they sell it new
[quote=97trd(???™)]the factory uses a large cuped washer on the top , you have to reuse it
yea thats what i was missing.. so i just used my 2002 mounts... worked good so far
do you have any odd noises like when backing up and turning outta the driveway ?
if you do its a easy fix , just gotta take the mouts off and grind the lip that is part of the mount , it rubs on the gold part the bearings are in
i couldnt find my pics of it
97trd.... do you mean grind it so the gold top part of the bearing sits inside the black steel cup better?
it should be sitting furthur in than what josh's second pic shows or what?
Please let me know.
farmerz24
not the gold piece , its the stock mount you need to grind on
it has a lip all the way around the hole and you need to take that lip off the mount , it rubbed on my stock 100,000 mile mounts and the brand new mounts i had
that part shouldnt be making noice... it should be sliding freely on the bearings.. i packed my bearings with grease before putting them in and i dont have any noices at all
yea make sure to grease the bearing otherwise it will squeek...... makes a hel of a difference in feel too
