I have a set of KYB AGX and i was just wondering what the adjustment numbers mean?. On the rear struts i see a adjustment knob that ranges from 1-8. I don't really understand what would be a good number to ride on? I want my suspension to ride smoothly for the street.
Question 2 is where is the adjustment knob for the front struts? I didn't see it .
My car bounces alot.  I know that when lowering the car the ride should be a bit stiff, but with the set up i have you can feel every bump. I am riding on B&G springs so i know its a decent spring for the struts. Do any of you guys that know more about these, would you say that maybe the struts are blown or is bounce that normal?
Well lets give you some info on these. The fronts adjust on the top with just a small flat head. You just have to push it done some and turn it to the setting you want. The higher the number the stiffer the setup is. Most of the time I have it at 1 or 2 up front and about 5 in the back. The rear is adjusted by that big numbered thing you see. Just turn them higher for a stiffer ride. Play with it some and just see how you like it, but the 2 in front and 5 in the back seems to be good. If you have a lot of bumps where you live might put the front to 1 unless you want it stiff all the time.
