rear im un sure on.
as for fronts, you need to pick up a set of the stock rotating bearing rubbers. i believe the 00-05 style is whats supposed to be used.
I must confess... I feel like a monster!
You need the lower part of the stock front mounts for the front. You take it apart and it goes over the strut and spring, then the aluminum pieces (smaller side up), then the OEM mount, then the nut.
For the rears, I'm unsure also, cause I've never installed OEM coilover rears...they were already assembled when I got mine.
Mmmmm....basics
Watching this for feedback
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
LoudCav wrote:You need the lower part of the stock front mounts for the front. You take it apart and it goes over the strut and spring, then the aluminum pieces (smaller side up), then the OEM mount, then the nut.
Wait dont you use the lower stock mount only if you use the stock mounts? Aren't these solid mounts? Do you have a pic? I have the same mounts with BG coilovers and i didnt use any part of the stock mounts.
ECOtec DOHC
Thats what I thought. Thanks Mark
ECOtec DOHC
Tein basics do not come with top hats. they come with the gold piece that allows the spring to sit against the stock mount.
Go Go OG Traction!!
What exactly are top hats? Do they go in place of the isolator housing or whatever?
Mark, where are they listed on your site?
Where do I place those two aluminum pieces? Do they go in the top hat?
all of these threads would be solved by creating some nice instructions for installation.
I had OEM solid mounts since last year and went through a lot of back and forth PM, IM and phone tag before i got it working. Clear instructions are a very important part of the product IMO. Even if its just a detailed how to on the org with good pics.
I did do a write up for a CO and NON CO application. The problem is there are so many different options out there.
For the top hats, tommy shoot me a PM or e-mail. They are $50 and I can probably get a set out asap for you. They are under the Nissan part on the site. I will be doing some work on the site tonight and will add them as an option.
Mark
http://www.overkillengineeringmotorsports.com/
oldskool wrote:all of these threads would be solved by creating some nice instructions for installation.
Probably a good idea. I know there are many different options for these mounts but all of them are made to order from what you had told me. So why not just print up some instructions while you are making the set? That would makes things much easier for us I think. Just a suggestion though.
This get figured out yet? Interested to see/hear install comments.
214whp 190wtq
No, not yet. Mark said I need to get his top hats for the front mounts, just haven't had the money to order some and get them installed. School is a pain right now. It's over in 2 weeks so by mid-december I should have everything installed.
Still working on this. I finally have the money to order the top hats to finish the installation but now I can't get in touch with Mark.
Anybody heard from him lately?
It's the holidays so I'm sure he's out of town like so many others.
Back to work next week so things will be back to normal again.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
Good point.
I'll just try him next week. Hopefully he will respond...
Ok wonderful!
And these go in place of the gold spring seats in the previous pictures, right? And I'm also assuming they fit in with the top of the cone facing up and the bearing and washers fit in that little lip at the top?
Definitely watching this. I'll be getting solid mounts for my basics this year.
