This probably gets asked alot and I was kinda affraid to ask it but couldnt find the answer anywhere. One of my calipers is bad so Im gonna do the responsible (and of course more expensive) thing and replace them both since idk the last time this was done. My question is of course, are there any bigger/better brake calipers out there that will bolt up to the stock breaks on my Z24 that I can get without having to buy some triple digit brake kit? I read the NWF sticky but it didnt state (unless I missed it) rather or not and of the calipers could be used without swapping everything else. If not then Ill just buy replacement calipers. No big deal just saw this as an opportunity for a simple upgrade and thought I would ask.
Pretty sure there is nothing that you can just swap on. Re-man'd calipers are super cheap anyhow for these cars.
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
You have to get the rotors and full hub assembly to do the NWF swap. The AC DElco replacement calipers for our cars are like $30 from the dealer though.
i can make you brackets but i would need to know what kind of caliper you would want to use.
im doing a subaru sti front and rear brake conversion on my car but im guessing that is out of your price range?
Well I guess I'll be buying remans from work. Thanks for the help.
Phil Lindsay wrote:i can make you brackets but i would need to know what kind of caliper you would want to use.
id like to see some progress on your swap
