ok now i found what is wrong with my prostreets, every time i turn the wheel the passenger side tender spring and main spring turn on the strut, i dont know what the hell to do, I got these 2 disc like things with bearings inside i think but i dont know if i'm supposed to use them or what?, the driver side doesnt do it so i dont know
PLEZE help me
thats the bearing i asked about in the other two posts...
you are supposed to use those )
rubber side of it facing the spring, and the plastic/white side facing the mount.
should be on on each side.  else the spring can actually start ripping rubber off the mount.
ok and how do i get thos apart? i turn them and i hear nothing but gridage, so i assume that they will have to be regreased..
L33tJbody (Brandon Gathye) wrote:ok and how do i get thos apart? i turn them and i hear nothing but gridage, so i assume that they will have to be regreased..
probably....
def learn from my experience, it sucked my first time cleaning these...... put them in a towel, and carefully and slowly pry apart the halves with a screw driver.  some may or may not pop out...
def dont do it over concrete or grass, cause theres about 63-67 small metal bearings inside.... hard to find if they start rollin and bouncing.
take each one out and put em in a towel or napkin and rub em all together... the towel will clean em etc...
line both halves with a bit of grease and one by one put em back in one half.
then make sure the upper is greased as well, then put it on top, like a sammich.
then rotate it back and forth to make sure its coated.
repeat on the other side.
