Lowering my 2004 - Suspension and Brake Forum
Lowering my 2004
Friday, October 07, 2005 8:02 AM
Without going the full blown air bag setup,wats an easy way to lower my car?The tire im going to look at is something around a 245-35-18.Id like no fender gap.Any ideas?
Ebay Sucks Balls.
Re: Lowering my 2004
Friday, October 07, 2005 8:49 AM
a good setup for a simple drop is eibach pro kit and kyb agxs. just remeber agxs are only good for 1.5" drop and anything past that should really use konis. Also i heard the gr2s are capable of a 1.5" drop too but im not too familar w/ them so you'd have to check. whatever you do just make sure you get struts too and do them at the same time. it will make life so much easier
Friday, October 07, 2005 8:53 AM
[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]a good setup for a simple drop is eibach pro kit and kyb agxs. just remeber agxs are only good for 1.5" drop and anything past that should really use konis. Also i heard the gr2s are capable of a 1.5" drop too but im not too familar w/ them so you'd have to check. whatever you do just make sure you get struts too and do them at the same time. it will make life so much easier
Yep. I guess the GR2s are now rated for 1.5", but I've heard bad stories in the past. Good enough if you want to go cheap though.
Friday, October 07, 2005 5:08 PM
What if I want to go at least 3 inches.Ive heard about a company called Ground Effects.do they make anything for this car?
Ebay Sucks Balls.
Friday, October 07, 2005 5:52 PM
Jeff Moore wrote:What if I want to go at least 3 inches.Ive heard about a company called Ground Effects.do they make anything for this car?
not sure. you should really ask Ground Effects themselves.
a 3 inch drop would require Konis
