Currently, I'm running a 1000W Xplod amp to two 800W 12" subs and a .5 Farat Cap. I want to upgrade my interior speakers. If I buy two 5.25" Tri-axial speakers with peak handling of 200W (not sure if that's for one or both, as the site I'm buying the speakers from sells the speakers in sets of two and says the peak handling is 200W), and then for the back, a set of Four-way quad-axial speakers with a power handling of 200W RMS/ 400W max, if I would need another amp to power these. My head unit is a Kenwood and pushes 50W per channel. I want to get the most for my buck, as I haven't much money to work with. That's why I'm trying to avoid another amp, knowing that I'll have to buy something that's going to have four channels (correct?) which will probably be expensive. Also wondering if Pyle is an ok brand.
(kinda funny, I'm looking at a 1400W 4 channel bridgeable MOSFET Amp from Pyle, and it looks verry similar to my Xplod amp in my trunk. Wonder if it's a Sony knockoff.)
you can run them off the headunit no problem. amp is optional.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
wysiwyg wrote:you can run them off the headunit no problem. amp is optional.
Do you think the sound will improve by upgrading from factory?
Also still wondering if Pyle is an ok brand
Michael ... wrote:wysiwyg wrote:you can run them off the headunit no problem. amp is optional.
yes, they will sound better then factory (usually)
and I would say pyle is a crappy brand.
If you need some speakers...lemme know, i can get some for ya for cheap just send me a message or email
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
are pioneers good for interior aftermarket?
Did message you a couple days ago via the e-mail server within the j-body forum.
Pioneer is definitely better than pyle. Go to some car audio shops, take a listen to what they have on their display, listen to some of the stuff your friends have, then buy yourself, as well as myself and wysiwig 2 sets of rainbow components
when i think of pyle, i think of pyle of poop.. pioneer blows them out of the water
98' Pontiac Sunfire SE
