I installed a pioneer HU in my 2002 cavy and it didn't work at all.  I used a multimeter to check voltage.  I'm getting voltage from the yellow power and black ground wires.  I turned on my ignition and checked the red acc wire, but i got nothing.  I checked my fuse panel and I don't have any blown fuses.  I'm not sure what to check next.  Any ideas?
hp is overrated...it's all about the g's
did you check the fuses under the hood? Also I'm not sure you should be getting voltage from your ground wire.....
Yes, I did check the fuses under my hood.  I had an aftermarket blaupunkt stereo in before, but it got stolen (ripped out of dash).  So I figured I could just color match all the wires from my dash(which were hooked up to my blaupunkt HU) to all the ones from my new HU.  I checked again and I am getting voltage from yellow and black wires, but nothing from the red acc.
Is the acc power wire ran to the ignition harness or fuse box? There is no acc power wire in the factory harness so if someone put one in they may have fused it behind the dash somewhere.
-Chris
all set thanks for the help guys
