Ok, I just finished out my sub and amp system in the back, and Im pulling some major power from my car. I already have a Optima yellow top, and the big 3 upgrade, and I still need more juice because my headlights and other lights dim on bass notes.
The options, as I see them, are either a 2nd battery hookup, or a high output alternator. I have been told caps, even 5+ fraud are useless for extremly high power applications. Now, for what I will be powering with all this stuff:
Current:
Alpine MRD-1005 Mono amp
2 Kicker CVR 12"s
Underbody & Interior neons
and some more minor electronics
I all also be adding a 2nd amp for my 6.5s in the front down the road.
Now, the question is, should I do a 2nd battery or bigger alt? What would you guys suggest for what I am going to be powering? I estimate a 2nd battery setup to cost me around $200-$250 for a battery and a hookup kit. If this was the path I would go, how would I go about it and what battery should I get? I am currently looking at
This for $120. With
This hookup kit for $100. Now, the only problem I see with that is this battery says its 850 amps, and the kit says its 250 amps? Would I need a bigger kit for it?
For a bigger alt, I was looking at www.exteremeamerage.com for a new alt. I was going to call them tommorow to get a price for the alt. For this, would yall suggest a 200, 250, or 300amp alternator? I do not know if you can get a amp that is to big... im completely new to alternators Lol.
Any help will be great, thanks !
"Laying in bed one night, I said "Where did I go worng?". Then I heard a voice say "This is going to take a while..."
Well I am pretty sure if you upgrade youre alternator amp output, That should cure youre power issues.
or get an optima yellow top. i got one and still have my stock alt. never drops below 12 on  my voltmeter even with stereo blarin, all lights on and sittin at idle
We Ride Together, We Die Together...... J-Bodies For Life!
SPONSORED BY: Showstopper Tuning, JM Graphics
2003 Cavalier LS Sport "SHOCKWAVE"
DEFINITELY a bigger alternator!!  That is where your power originates from!  If you have too small of alt..you can put as many batteries in your car as you want.  But if the alternator doesn't have enough power to constantly recharge all of them, it is useless.  Go with a bigger alt, and your problems will be fixed.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
do you have a power Cap if not you need one and if that system is killing your alternator you definately need one Im running easily 6 times that with one battery but with 2 40 farad caps
^^^^^ cap = crap.  They're useless.  It's like pissing on a forrest fire.  Do the big 3, check on maybe a bigger alternator, something around 200 amps would be plenty for you.
^^ lmao.....    Yeah caps...zzzzz.....+1 for the alternator...You definately don't need a 300.  A 200amp one shouldn't be hard to find.  I think you can get your stock one rewound to a higher output as well, if you have a shop around that does that.  Maybe something else you can look into.
LOL
^^^ I'm curious as to how?  I was pushing ~1200 in my cavalier with a stock alt, and the big three and my amp got fried within a couple months.
LOL
alternator***got fried..not amp
LOL
i'm runnin 1200 watts on the stock alt and all i got is the yellow top and a 1 farad cap. it works great for me
I am running 1000 watts atm, but I will soon have another amp, plus some lighting in my car... so im thiniking ahead mainly
I think I am going to go with the alternator as you all said. I already have The Big 3 and a Optima yellow top.
Cap = Band-Aid
Don't even bother...Don't try and cover up the problem..it likely won't even fix your problems anyway....Just fix the root of the problem..the alternator.
1997 GMC Sierra
2005 Honda TRX450R
Where would the best place to get a 200amp alternator from? I was looking at www.exxesiveamperage.com but they said a 200amp w/ overdrive pully was like $300.00. Is this a good price for one of these? Im completly new to alt and pully info, any help would be good on where to get one of these.
I'm running an 1800w amp on stock alt and an acdelco battery, no problems what so ever.
I LOVE MY 2000amp Kinetik Powercell (Battery) in my car.  They work verywell, and ARE DESIGNED FOR CAR AUDIO!
Where did everyone get there alternators from and about how much did you pay for it?
i got mine from excessive amperage, but it's a big case gm with external voltage regulator.
I was doing 4500 rms there for a while with my stock alt and i had no problems, other than voltage drop.
Ok, I found a 160amp alt on Ebay for sale for $169.99. Would 160 be enough for me or should I stick with getting a 200? I just noticed them seem to cost a lot more than the 160s
you want to run heavy power...your lights are going to dim a little. it's not the end of the world.
now when they shut off completey and your car dies when you burp it...THEN you need to start to worry, lol
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
im running 750watts per 12 inch ( i got 2 )  and a large cap and thats it and its great .... doesnt dim the lights even when its pounding ...... but i was told i should get my alt rebuilt  if im gonna be pumpign it constantly .....  getting it beefed up would cost 100 - 150 but get  double the amp power from ur original .....  this is in toronto ontario .... dunno where ur from but  theres many places around here u can get them rebuilt ...... that way u dont have to pay for the core price of the thing if u wer to buya new one ...
p.s im using a bosch stock alt and a  ac delco battery ...... untill it dies or i notice a large dimming issue .... im not changing a thing .
Not to thread jack but i have a Memphis 1000 what rms  2000 what max amp with 2 Diamond audio 12's.   I want to get a 200 amp alt.  Is there any electrical upgrades i need to do to support the alternator.
