wiring under dash by ODB port?!? - Audio & Electronics Forum
Tuesday, September 02, 2008 4:59 PM
So i've had this car for about 4 months now (2002 Sunfire SE 2.2L OHV) and when I got it, the blinker had some problems and it would stop working externally and internally it would blink really fast. The dealer fixed that after about 3 trys. But now i've always wondered what all this crap under my dash was. It looks like it was plugged up to something before I owned it...like a ECU flasher?? I have no idea...what is it? It also looks like there are some fuses or what not...I can take some higher res photos if needed...these just came off of my phone.
Thanks for the help...
Re: wiring under dash by ODB port?!?
Tuesday, September 02, 2008 5:01 PM
Note: These where here before and after they fixed my blinker problem...i told them to fix the wiring cause I thought it was this huge gob of wires under my dash..and all they did was zip tie it up and out of the way.
Tuesday, September 02, 2008 5:05 PM
hard to tell with that pic quality but my guess would be some sort of aftermarket security system
Tuesday, September 02, 2008 5:09 PM
ah true could be, i have manual windows and locks too, if that has to do with anything, cause im sure security systems are tied into those.
Wednesday, September 03, 2008 11:28 AM
Anybody know? I had one of my friends look at it and he's not sure either..im going to unwrap all the electrical tape off of it later today. It appears that it is spliced into the blue or green or both wires that run horizontal under your dash.
What are the blue and green wires to?
Wednesday, September 03, 2008 2:24 PM
That's an aftermarket alarm or remote start alright...look at the harness. If you are good with wiring AND ONLY IF YOU ARE GOOD WITH WIRING, disconnect the battery. follow each factory wire one by one and eliminate anything aftermarket attached to it. Then reconnect the factory wires. Go to the junkyard and take high quality pictures of what the wiring should have looked like in the first place before you begin. I won't promise anything because I don't know if there is anything else wired wrong in your car. But I would be willing to bet this fixes most of it.
If it can't drag, it ain't low enough!
Wednesday, September 03, 2008 4:36 PM
Its running fine, its not affecting anything its just a nucience with all that crap tucked up under there. It also has a relay and some fuses in the bundle of wires. When I got the car it also came with 2 key fobs, but since my car has manual windows, and i suppose that means manual locks too, I figured they were pointless.
What can I buy to hook up to this..I kind of hate having all that wire there serving no purpose.
Wednesday, September 03, 2008 7:34 PM
those green and blue wires that are under there id put money on them being to a set of door actuators.
Wednesday, September 03, 2008 7:39 PM
n8 is probably right. and unless it says the brand somewhere on the harness, you're pretty well screwed on matching it up to a brain....just get rid of it all wire by wire. Then take ur door panels off and see if they did install actuators for power locks, if they did, you can buy a keyless entry brain with two remotes for about $50. That's what I did for the two solenoids I have laying around...now I'm ready to go fully shaved and suicided on my Cavy doors.
Thursday, September 04, 2008 4:31 AM
That may be it! because these two wires are running under both the driver and passenger side and they go back behind things.
Let me do some digging around and ill get back to you guys.
Thursday, September 04, 2008 12:16 PM
Turns out that these two blue and green wires deffinitley go into the doors. I have the key fobs and the Model number is AVX01BT3CL3.
So im going to find out what module I need to buy to get this to work.
Thursday, September 04, 2008 7:58 PM
i would buy a whole new one and have it installed. the actuators in the doors is the hardest part. you probably already have the relay and everything for it. AVX means its a prestige made by audiovox though hope that helps. do you have a siren under hood or a hood pin? can you see where one was mounted. it could be just a remote start or keyless entry.
Friday, September 05, 2008 4:21 AM
Yeah the relay is hooked up, I can see the little relay box hooked up under there. And for a siren under the hood or a hood pin...im not really sure..I've had my hood open multiple time and have never noticed a speaker for an alarm..were might it be located? Im pretty sure this is just keyless entry...which would be great to have.
I think this is what I need, I looked up the model # on my key fobs and I get this kit and one other.
http://www.amazon.com/Audiovox-APS45B-Keyless-Entry-System/dp/B00020C5W4/ref=sr_1_1?ie=UTF8&s=electronics&qid=1220579838&sr=8-1
