Well I bought a 2000 Saturn SL1 to get me to work and back. CD player not playing CD's, passenger side speaker blown to bits. It NEEDED to be upgraded.
The install: Had to keep a tight budget as I have too many hobbies going on right now. Simple, hidden, all about the sound and keeping cargo space. This is my DD, I wasn't going for a show car install. It had to take as little space as possible.
The equipment:
-Rainbow SLC265.25NG components
-Rainbow 12" Hammer in sealed box(Rainbows pre-matched set up named the "Stream")
-Soundstream Rubicon RUB4.600 amp to power it all
-Alpine CDA-9886 head unit
The pics:
Amp mounted-
Crossovers mounted-
Tweeters mounted(you can almost see the pass. side mid. Just a round speaker bolted to an MDF ring, so I didn't think to get pics)-
Sub sitting in place, trunk all carpeted up. No more amp or crossovers
Another tweeter shot-
And the shot right after installation of them, before putting the dash pad back in-
Like I said, nothing special. Just my daily.
(tabs) wrote:z yaaaa wrote:its not much fun trying to argue with a wall.
oh, trust us, we know
Thanks man, like I said that was the goal. I have a lot of gear I need to throw in that car from time to time, so I wasn't going to have a big fancy install showing everything off lol. Also looking into a more full grill for when I do fill the trunk.
Haha thanks Jason. That's not a terrible idea although I'm not entirely sold on the idea of down-firing in a trunk.
i was thinking about doing it in my trailblazer just so i didnt have to worry about hitting the sub or banging it up. just have to figure out how much space you need. i believe its something along the lines of enough area in the opening to match the area of the sub itself. it;s either that. or doing a fiberglass enclosure under one of the windows. but i dont know if i wanna go thru all that for this since its just like yours a dd install.
JL how do you like the soundstream rubicon or just soundstream amps in general? Seems like they would be an upgrade from my power acoustiks.
Dave
David, I had let my premium membership lapse, so I was out of posts until today. I sent you a PM.
Looks like @!#$.
Never saw you as a Soundstream kind of guy.
For a tight budget they make some decent stuff. Do they hold a candle to the rainbow ipaul4.300 I really wanted? No, but I couldn't afford one at the time.
im not much of a audio guy but very clean install
So I was thinking about this the other day. Did you do any time alignment with the tweeters on the dash? If not how do they sound up there? Ive been wanting to take my tweeters up higher (a-pillar or dash) but I dont really have any time alignment to work with.
I have not so much as even touched the imprint module yet and its not bad. I'm sure I can fine tune things much better, but I've got things quite good with no problems or major time into extensive tuning.
And brad, its a washer covering the entire surface of the terminal holding it will thrived bare metal on the unibody chassis in a major part of the structure. Not having an issue with ground at all. And I have pretty good fender liners, so I doubt it sees too much grime. If that ever becomes an issue I can get under there and spray some indercoatng over the underside of the hole/bolt
"will thrived" seems to be a typo/autocorrect from my phone which should have read "to",..... how the hell?
