anyone have pictures of there car that has the metal above the fuel pump cut out as a "trap door" persay to gain access to the fuel pump without having to drop the tank and what did you use to seal it back up?
anyone know where to get the black venturi hose from?? mine is pretty much screwed and i wanna just swap that out
For gods sake if you do this just plz make sure to remove the tank before cutting into the floor ... I know a guy that drilled a hole in the floor  under the rear seat and well he drilled right into the top of the fuel pump assy ..
 I'm about to install a racetronix pump and harness and was thinking about doing some kind of door also.If my pump comes in this week then i will install it on Sat . I will post pics then ...
Good luck.
Ill have to see if my friend Devon has pictures of his in his 3800 s/c cavy. Its pretty slick.
got the car home today finally, loading it on the trailer was complete GARBAGE but its done and home !!!!!!!
was wondering though, where can a person get "JUST" the black venturi hose for the fuel pump??
BUMP, I need to find a place that i can get the black venturi hose from, auto shops want me to buy a whole new pump assembly
