I am running a Garrett GT3071R and will be pushing close to 20psi. Was curious as to what you guys suggested for injectors (brand/size)
Injectors aren't sized by the turbo used or the expected boost pressure, unfortunately.
They are sized based on horsepower output at the crank / amount of injectors used... x amount of horsepower will require y amount of fuel flow divided by z amount of injectors.
With that said - what is your horsepower goal?  Will you be running an upgraded pump and harness?  Stock sized fuel lines?
-Chris-
-Sweetness-
-Turbocharged-
Whp goal would be 300-350 I am guessing. I put down 215 with 8psi. My current injectors are currently 36# The car has a Racetronix 255 pump with stock lines
Grab a set of ID750 they will be more then plenty for you and give you room to grow
RIP Cpl Derek Kerns And Cpl Robby Reyes
24th MEU VMM-261 (REIN) V22 Crewchiefs
11 April 2012 Morocco (African Lion)
Go thru t1racedevelopment they are cheaper
Thanks, injectors are kind of  foreign to me, but hopefully I can get the right ones.
With the id725 at wot they would be roughly be 850cc and if you are running 20psi then they would be roughly 950cc more then enough for now and a lot of room to grow I have the ID1000 and will have them up to about 1500cc at 90psi 60 base with 30psi boost = 90psi boost referenced setup
Right on...been reading a lot, and real life examples are always best! Thanks!
