Currenty lowered on sportlines and looking to go coilovers next year, but I'm also looking a 18x8 rim am I going to have rubbing issues with an 8inch wide rim??
I have 18x8 with 42mm offset and its tight. I rubbed some of the under coating off on the inner metal frame. So we're talking millimeters.
02 redbadged wrote:you'll be fine.
let me take that back.  you'll be close as stated.
go with a 42mm offset.  that'll be perfect!
 WiGM-Tuners member.
WiGM-Tuners member.
Take it from me as I was going to run a 8 inch wide rim with coilovers. If you go with teins your going to run into problems with the rims, just giving you a heads up. Anything below 40 offset should help you out when running these coils, yes it'll push the rims out more but you wont have to worry about your rim touching anything. Its better to be safe than sorry down the road also remember to roll your fenders as well
 Click Sig for Jersey GM's Official Website
