Hey, I was wondering if anyone knew how to remove the lower steering column cover, specifically the tilt lever. I know to unscrew the two screws on the bottom, but I don't know how to remove the tilt lever, which it says to do in my Chilton's manual. Any help is appreciated guys, thanks.
All I have in this world is my balls and my word, and I don't break 'em for NO ONE.
turn it...it just unscrews
you will probably need to use some pliers or something like that cuz its put on with loc tite or some sort of glue, but if you use those cover the lever with an old towel or something of the sort or you will destroy the rubber coating. and to get the bottom steering column peice off, there is 3 T15 torx screws that you need to loosen to get it off, hope this helps you out
-Mike
simple minds talk about other people.
average minds talk about events.
great minds discuss ideas
You can actually hold the piece on an angle and bend it over the tilt lever. That's what I had to do. Done it twice now without breaking it, though I offer no guarantee.
Before doing it the first time, I tried unscrewing the lever and only managed to chew it up pretty good. It didn't budge.
use vice grips and unscrew it that way you know its on there tight and wont slip an scrape it up.
CayenneRedZ24 wrote: I know to unscrew the two screws on the bottom...
I thought there were 3 screws under there...
