i have a 2000 sedan and i wand to fibreglass the headliner i'm not even sure if i can take it out nevermind put it back in fibreglassed. do i have to do something extreme like pull the back windows out or what?
no you just pull it out. i can never understand how people cant figure out how to get this in and out without bending it. you just undo the screws holding it up. spin it 90 degrees and slide it right out the door. no bending needed no removal of windows none of that is needed. i personally would fiberglass the piece in the car with it still intact, do a few layers, then pull itout and get the areas around the a-pillars and back by the rear side panels that are still undone, fiberglas shrinks when it cures and if you just pull it out and fiberglass it, it will shrink and when u put it back in the area along where the door is will sag down heavily. the only way of fixing it then is to use screws with plastic covers to hold it up. doesnt look as good that way.
http://www.flickr.com/photos/sndsgood/   https://www.facebook.com/#!/Square1Photography
