fiberglassing question - Interior Forum
Saturday, December 02, 2006 2:00 AM
So tonight i started grinding the pass side of my dash/pillar down and got what i think was a air bubble grinded out of the glass, so how do i go about taking care of it?? use filler and fill it in?? also you can see in the pictures where the holes are i cannot fiberglass because the guage will not slide in the pod right should i do so
thanks
for the help, i know sndsgood will probley get the cake for this one lol!
http://i134.photobucket.com/albums/q94/gmto2nr/glassinthepod004.jpg
Re: fiberglassing question
Saturday, December 02, 2006 12:37 PM
You're gonna have to put some glass on it. Use small pieces of strand mat, not the woven mat. Put some resin down, stick a piece to patch up the hole and apply ample amounts of resin. Repeat. When you build enough back up, just sand until the gauge will fit.
Woooo bubbies.
Saturday, December 02, 2006 1:29 PM
Jordan Johnson wrote:You're gonna have to put some glass on it. Use small pieces of strand mat, not the woven mat. Put some resin down, stick a piece to patch up the hole and apply ample amounts of resin. Repeat. When you build enough back up, just sand until the gauge will fit.
Yep.
Either that or you might try glassing it from behind. IDK if you still have the vinyl or something.
-Seth
Monday, December 04, 2006 10:21 AM
as said above. if the hole isnt very deep you can fill it with filler, the fiberglass over it. but if the hole is pretty deep your going to have to lay some fiberglass in it. might try cutting some very small pieces of fiberglass. wetting them with resin then pushing them in the hole to fill it, when it hardens go with some filler to make it smooth with the opening then add alayer or two of f/g over it. and i forgot you had wanted to call so i'll pm my cell # in case you still need to get ahold of me.
Wednesday, December 06, 2006 5:56 AM
personally I would cut it off and re start it, those solutions above are good ones but you will need to ad filler to smooth and its just not going to work since your already having space issues, trust me do it right the first time its not worth doing it over again
