Search failed to help me here, but I'm not even sure what to search for, or if this is the right part of the forums to post this issue.  When I turn my HVAC to any position that is supposed to blow out of the dash vents, only the two side vents blow air out.  The middle two feel cool and air is coming out, but about 1/100th as much as the side vents.  It has been slowly getting worse and worse since I got the car, and I don't know where to start checking...  I can't see anything back in behind the vents that would stop it.  Has anyone had this issue, or know of a fix for it, without tearing the entire dash out?
Eilliam
<img src=http://members.cox.net/eilliam/leersig.jpg>
*sigh*
Take apart the dash, remove the ducting, reposition the foam, and reassemble everything.
^^ I have the same problem. Now i now how to fix it. Thanks!
happened to mine there was foam blocking it ripped that bish out.
GOD : The way, the truth, and the life.
