I was wondering if people can show me pics of where they mounted there PCV Catch Can
You dont need it, just run the hoses to atmosphere!
Thats what im doing.
Check out "slammed and kitted cavi" in this forum
Then look at my modified ports on my valve cover!
oil Comes out of your breather ya you do need it. Beside i want to run it from PCV to Intake vacuum. that occur actually helps remove containments from the crank case. I just dont want the oil going into the charger. Right now i have it to atmosphere
its best to atmosphere!!!!!
So your telling me that contaminating you good intake air with blowby gasses and oil is good for your engine!
the contaminants will follow the path of least resistance ..... thru the bigger ports in a mod'd valve cover
ok sorry for trying to help you them!!!!!
He has a 2.4,for the most part on a stock 2.4 system the blow-by will be burned of by normal combustion,most of us put a filter on after removing that tube but in his case,no, a catch can is the way to go.
Shroom:there was a thread somewhere that had pics of catch can setups on the 2.4
Phil Lindsay wrote:its best to atmosphere!!!!!
Did you read my reply at all? It clearly says I WANT TO USE A CATCH CAN TO PREVENT OIL from going into the supercharger/intake, in my case i have increased pressure in my crankcase from the supercharger. What do you think a catch can does? The vacuum that the intake creates on the PCV helps remove contaminants from the crankcase! So why not put a Oil Catch Can between the PCV and the Supercharger.
Beside this post was about seeing where people mounted there Catch Can, i was just wondering because i saw Ruens setup which was awesome so wanted to see what others did.
I'm interested as well. Have any pics of ruen's setup?
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
I just rivited mine to the radiator support, near the battery.
Paying someone to install parts and bragging about it being fast, is like watching someone bang your wife and being proud to raise their kids.
^^ ahh an aooooga horn^^ saweet ok back on topic.
**changes are here**
