I ran my car at the track last weekend and i was wondering if my times were any good.  From what i understand my trap speed should be putting me somewhere in the low 15's and not the highs.
R/T                  .125
60'                       2.264
330                      6.599
1/8                       10.140
MPH                    70.61
1000                   13.186
1/4                       15.759
MPH                     88.50
Altitude is 1250'
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Not bad, could be a little better since your a manual. I ran a 15.6 in my auto with your mods plus a 2.3 lo manifold and 58mm tb. Id look into the 2.3 manifold and tb next, should drop you a few 1/10's and not too much money.
bump
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Racing section doesnt get much action unless its something thats running like 13's or faster.
Give a little more info on your runs,what was your tire setup,what was your tire psi at,car make,model,year,auto or manual?Most won't look in your profile because were lazy
i ran 15.38@89mph when all i had was engine mounts, and air intake
i got Drag Radials the following year and ran 15.11@90mph
you can pick a couple 1/10 up on the 60 foot that is decent but i was consistant 2.1 on street tires and 2.0 on the drag radials
205/55/16 street tires on ls sport rims,  20psi  2001 z24 5 speed
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
seems to me 20psi is a little low?maybe not, try some different rims/tire setups,like 14's
20 psi is to low.  i say on street tires dont go any lower than 28 psi
I went to the track again 2 weeks later and these are my times......
R/T            .500
60ft            2.304
330            6.585
1/8th         10.116
MPH          70.92
1000          13.155
1/4              15.715
MPH            87.52
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
