This is what happend when i was half asleep and didnt pin my hood shut
windsheild is $225 plus tax, new hood hinges are about $50 and i have to replace the hood pins and windshield wipers
. Luckily the fiberglass didnt crack though
The Only Stupid Question, Is The One You Don't Search For
I bet you werent half asleep that
Sorry man, I don't mean to laugh but thats just too unreal.
I do feel bad for ya though, the hood/fiberglass prabably cost the most anyway right?
by the way, hood latches/locks look cool, where do you get them.
why dont you use your stock hood latch?
Everyone I know with hood pins just undoes them, then releases the hood latch...sux for you, though!
So...pretty much anyone can just come up to yer car and open yer hood? I would not feel safe knowing that. one snip to yer alarm power and everything in yer car is gone...BTW: where do u live? jk jk lol.....that sucks tho
I've got a hood latch.. why werent u using your latch
<Img src="http://www.icefire.ca/stylez24/stylez05sig.jpg">
Official member - www.ontarioCAVS.com & J-Body Club of Ontario
You didn't notice a rattle, or the hood moving with the wind...?  How fast were you going when you realized the hood was moving up and down with the wind??  LOL
I have done something close to it...
I had a 79 Camaro with T-tops, needless to say the passenger T-top wasn't latched, first left turn and it flew off and slid down 2 and a half blocks.
It was just scratched up horribly, but not broken.
And I am with everyone else, why did you remove your stock safety latch?
I thought you only needed hood pins a C/F hood. I thought fiberglass would just use the stock latch?
It's a good idea to use pins on a glass hood also.
I've seen glass hoods blow out around the orig latch at higher speeds.
I've got a Vis Evo hood (CF) and I use my stock latch...havent had problems yet but the hood doesnt fit all the well so i'll have to get pins I guess, though I really dont want em!  But yea, you can use the latch with a CF hood. Why didnt you have it latched!?
any kind of lighter hood, i use pins.  just to insure my investment.  it latches w/ the stock latch, then i pin it down to be safe
i was only going 25 mph when it happend. and it wasnt bouncing because it was wedged with the hood pin mount. the first time it moved was when it did the wonderful piece you see above. i took out the stock latches and put in hood pins so the hood would line up better with the fenders. I also got the pins because with just the stock latch, when i passed a trucker on a two lane highway it seemed like the hood was going to fly up or crack.
on my 03 fire the hood bounces around like you would not believe.  its all stock.  the hood just sucks.  im waiting for the day when it flies up.  its gonna suck i know that.
when you add hood pins your supposed to pin AND latch the hood
so since i have a fiberglass hood yous are sayin it would be wise to pin it also?  the stock latch does seem to be workin fine so far and ive done over 80 mph already?
The stock latch is fine if you have a GOOD QUALITY hood. I have a Race-Tech hood, and the stock latch as well as the hinge bolts all have metal inserts inside the hood instead of just threading into the fiberglass.
I've seen several low quality cheap fiberglass hoods that do not have metal inserts. These ones I would worry about. I've had my hood on for three years and drive on the freeway every single day, and i've never had a problem.
 Club Vantage
Club Vantage ::
importfighter.ca :: RIP Trux0r...
ive done this on my 87 iroc.  the hood musta lifter 20 ft in the air.  but just cracked the corner a little bit
Ironman wrote:The stock latch is fine if you have a GOOD QUALITY hood. I have a Race-Tech hood, and the stock latch as well as the hinge bolts all have metal inserts inside the hood instead of just threading into the fiberglass.
cheap hood has nothin' to do w/ it.  all it takes is for wind to get up under the hood.
I had a fiberglass ram air hood that wieghed less than 15 pounds for 2 years and never needed pins.  Stock latch works just fine.
Shawn wrote:on my 03 fire the hood bounces around like you would not believe.  its all stock.  the hood just sucks.  im waiting for the day when it flies up.  its gonna suck i know that.
i remember my hood used to do that back when my car had the stock hood on....hood pins on my CF hood definately took care of that
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/pkdTiDb-kdPf_HDyfmy7GOrOdkeUy2ptYquaYUHMJPs?feat=embedwebsite"><img src="http://lh5.ggpht.com/_vycyMdOjDVs/TQqUHgW0ImI/AAAAAAAAABo/iS19dM4snS4/s800/firesig.jpg" height="169" width="310" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/116733817284633862727/DropBox?authkey=Gv1sRgCMS-wbij1e6GuQE&feat=embedwebsite">Drop Box</a></td></tr></table>
What exactly happens? Does the sticker come out of the hood? Does the actual latch give?
Should read stricker, not sticker.
oooooofff that had to hurt
Ryan
