3400 not idling - Other Cars Forum
3400 not idling
Saturday, May 16, 2009 6:52 PM
i have a not so jbody problem but i need advice. i have a 2001 3400 v6 that i just did a head gasket job on and now i cant get it to idle by itself and it has a hard start. if i pull a plug out it runs great and starts fast. help me please
2004 Cavalier, 2.2 ecotec, 5spd getrag
do you ever notice that the ones who talk the loudest have the least to talk about?
Re: 3400 not idling
Saturday, May 16, 2009 9:52 PM
I would start with the simple things.If the vehicle ran fine aside from the current work done then look at the most obvious.I would look for unhooked vacumm lines,check the tps,wires going to coil packs.Now if the basics are checked already and it's not popping up codes do a fuel pressure check (long shot) maybe a clogged filter or fuel pump going.I am not fluent with the engine at hand but,in alot of cases symptoms are symptoms and relate regardless.I would def check the tps for voltage to assure the when u use a jumper and physically move it that the multimeter has a gradual change and not quick or irratic change.I cannot explain how to jump it with out writing a book,but this site can show u how http://www.wellsmfg.net check out diagnostics volume 2 or just do a search for tps it should pop up.Hope this gives u some leads to the issue.
Re: 3400 not idling
Sunday, May 17, 2009 7:28 AM
hmm thanks man, i appreciate the advice. ihave checked almost all the simple things. i have not checked the tps or fuel pressure though. it did run great before this work though. and even now it runs like a new engine. again thanks
Re: 3400 not idling
Sunday, May 17, 2009 7:44 AM
oh and i forgot to mention, i htink the cylinders are washed too. it acts like its flooding sometimes. and the oil smells like gas. my friend suggested plugged cats so i dropped the exhaust, it helped it start easier but still didnt fix it
Re: 3400 not idling
Sunday, May 17, 2009 12:38 PM
check the fuel pressure regulator , they are know for going out and feeding fuel back in though the vacuum line
pull the vac line off while running and see if gas is coming out of it
Re: 3400 not idling
Monday, May 18, 2009 3:20 PM
strat81 Online
fpr...
had a similar issue with a 2.4 cavalier where it was a hard start and ran like @!#$.
