I recently got my engine rebuilt for my 2003 Cavalier so the engine can handle 400+ hp from the turbo that was installed. I got it on a dyno and it was tuned to 226hp @ 5 lbs of boost. This turbo is capable of 600+ I need performance fuel injectors, and something to replace the ECU that I got now. I also need a new clutch that can handle the hp. Other than that I think I should be good. All this electronic @!#$ is a pain in the ass.
You should not need a new computer. Get the components you said you needed, and get it tuned again, or get HP Tuners. If there was a need for a new computer, your car shouldn't run.
2002 Cavalier "LS Sport"
Good luck tuning out 600hp on a stock ECU. Look into one of Hahn's port fuelers.
Mitsu TD06-20g |3" Turbo-back Exhaust | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | Team Green LSD | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
