I need the part number or a way to get my hands on the passenger side (if it matters) tail light harness. Basically, the harness about 6" long that the bulbs plug into, that plugs into the rest of the harness. I'd hate to have to order a complete tail light from GM because it's expensive and I don't need it. Please let me know. Thanks gentlemen.
all you really need is a 3057 bulb socket that has the 2 wires coming out of it not really a special harnesscuz you use the stock one just spilt up
simple minds talk about other people.
average minds talk about events.
great minds discuss ideas
I just sent him an e-mail. Thanks Shifted.
Homunculus[6(sic)6 wrote:]all you really need is a 3057 bulb socket that has the 2 wires coming out of it not really a special harnesscuz you use the stock one just spilt up
How do you split the stock one up? I was under the assumption the Toyota tails have two different bulbs in the corner lens, one for braking, the other for turn signal. If you split the wire up, wont both bulbs turn on at the same time if you put your signal on or step on the brakes?
you do need the 2 different socket, but when you cut the white wire under the top steering column cover it keeps the red bulb from blinking with the amber one, i dont remember why but thats how it seperates the 2
Homunculus[6(sic)6 wrote:]you do need the 2 different socket, but when you cut the white wire under the top steering column cover it keeps the red bulb from blinking with the amber one, i dont remember why but thats how it seperates the 2
I know all that, I did the wiring conversion over a year ago. I'm just having brake light problems with now. I the same problem with the passenger side first, replaced the harness when I replaced the tail light because it cracked and got a new harness with it from GM Parts Direct, and it fixed the problem. So I'm hoping getting a new harness will fix the problem on this side too.
TTT does anyone have any information for me?
well what exactly is the problem????? You should be able to make your own harness or repair the one you have......
P&P Tuning
420.5whp / 359.8wtq
ImPhat0260/Cavattack2000 wrote:well what exactly is the problem????? You should be able to make your own harness or repair the one you have......
My driver's side brake light does not illuminate fully. The parking light comes out, but it doesn't get brighter when I press on the brake pedal. I had the same problem with the other side before.
