hey, I am looking at making a set of LED tails for my 2000 sunfire. been reading up on this and realized I havent gotten a clue what I am getting in to. I am curious to know what size led's and how many mcd's they should be? I am alos looking to use them in the winter so are there certain ones i should buy? Is there anything that I should know about this job before I start it? any help would be greatly appriciated. thanks alot
Broda
patience, patience and more patience to start with.
I'm using 3000mcd amber and 5000mcd reds on mine.
Others are using brighter ones (which I'm considering for the brake lights).
As for where to get 'em, ebay ones are just as good as
LSDiodes.
For the resistors that you will need, go
here or
here.
For more info, click teh sig.
ok so i was on ebay and it says they come with resistors, how do i know if they are good enough for what i am gonna be using them for?
also how do i go about mounting these to anything?
thanks
Broda
A resistor is a resistor is a resistor... As long as it's the proper amt of ohms/watts for the LED's (might have to run the calc's above) they will work. I believe that they ship the resistors to LED's at 1:1, so you probably are going to have to buy some that are of the proper resistance... Use LSDiodes for that.
As for mounting you have several options
1) Plexi sheet with holes drilled so the head of the LED fits snugly (epoxy on the back side to hold 'em)
2) RadioShack pre-drilled perf board
3) Custom designed/drilled PCB.
so i looked on lsdiodes and didnt really find anything for resistors but i found these at another site, are these good enough?
link
kardain do you have any other pics.....those look bad ass
Anthony George wrote:kardain do you have any other pics.....those look bad ass
That's as far as I have gotten on my project thus far. I have the lenses from IZN and am still figuring how to mount the LED panels and the lens itself.
Johnathon Broda wrote:so i looked on lsdiodes and didnt really find anything for resistors but i found these at another site, are these good enough?
From LSDiodes (prolly cheaper than Ultra cause it's in USD, not sure...):
Clicky - Resistors
All mine came from one of the Hong Kong sellers...
http://stores.ebay.com/uBiditnow-LED-Shop
Out of the I don't know how many thousands of LED's I have currently, only 4 were DOA.
Thanks for the link Dennis, I'll check that seller out when I need more.
