ok well im gettin my doors shaved. and i wanted to kno wat if my battery dies and i have no way of gettin in the car.. is there a way to get a emergency unlock switch that doesnt need power.. any comments are welcome.. please help me out! thanxz in advanced...
hey ceaser you can also put a battery post under the car so you can jump the battery to get in. thats just another idea. i know people that have done that
Cut your stock Hood Release Cable, then fabricate a handle and a mount for it so you can open it from outside the car (Under the bumper, in the wheel-well, etc.)
i just purchased these from jegs and will be doing external jumper posts. If you decide to go this route these are the only posts i would recomend. payed like 25shipped for them and they were here the next day.
^^damn right bes tpossible investment to thouse with shaved doors. althought my spal kit came with one.
err i mean the spal kit came with one of those "emergency buttons" fuse holds just enough to pop the drivers side if battery dies. but i still got the exteral battery terminals aswell.
I have a hidden cable with my shaved doors. Try that if you don't want more battery post.
the best idea i've thought of (which i've used on a car) is to run a small wire directly to the solenoid and hidden under the car somewhere. if your battery dies, get some type of 12V source onto the wire, and voila, the solenoid pops. mind you, this wire would also be just a wire hanging around in normal cases. i used a 16gauge wire for it, which in all honesty for solenoid's you're supposed to use 10-12 gauge, but since this wire is for emergencies only, it worked just fine for one pop.
if not, i hope you've got a good set of tints so you can break the window and the tint will hold the window fragments
