put my car into gear, 03 4dr automatic, and the DLR light in the dash blinks like 5 times then the service light comes on, so I have no DRLs, turned on the nightlights and they arnt working at all either...bad fuse? blown both the bulbs? uhh.. anyone have this problem before?
Replace the bulbs, thats why the DRL light is flashing and the SES comes on. Either they are both blown, or one is. Just buy a new set, or upgrade to some good aftermarkets like PIAA or Silverstars.
got some silverstars put them in still nothing, high beams work and nothing else so im not 100% sol, went back to autozone and the dude told me its the multi switch... ??
the light/cruse control lever thingy i guess... 50 bucks but I cant do it cuz you have to take out the airbag to replace it. The autozone guy also told me that it goes bad on alot of cars... anyone else had this problem? even though no one is even freaken reading this gosh you guys are supposed to help your fellow members so gimmy some help please!
my multi switch went out last year, couldnt get my low beams to work AT ALL, you DO NOT have to take out the airbag to replace it...just unscrew the bottom of the column that holds on your cover, take it off and locate the bolts that hold the switch there....if you have cruise control unplug the electrical connector, then replace and SHAZAAAAM....lights (if that really is your problem)
is it really that easy to fix?
believe it or not it is that easy. just unscrew, wiggle, pull and replace. I just got done changing mine this morning and im still having problems though getting my high beams to work right.
now if i had the money, just got some new bulbs, and a badly needed rachet set, so im broke
