Was wondering if it is possible to switch the headlights off 03 cavalier to an 02 setup. I know you can go from 02 to 03, just wondering if it is possible without a lot of fab or splicing work.
you could read the d
amn sticky  at the top of the page
No fab and no splicing needed.  Fenders are the same between the years, and all 00+ Cavs used 9007 bulbs.
all you will need is bumper hood and headlights. and you can do the swap. very simple
Stephen,
Most people swap from a 00-02  to 03 style not from 03 to 02. That is pretty much what that sticky is for. People like you are the reason why I do not post much on this page; and the reason why some websites like these get bad a rap. Thanks to everyone else for your help.
well it makes sense that if you can go from an 02 to 03 that you can do visa versa.  all cavaliers from 95-05 are pretty much the same and alot is interchangable.
^^ not to mention most sunfire parts...
Richard Klick wrote:Stephen,
so how would it be any different? this question has been posted hundreds if not thousands of times. That was Stephens point.
pretty sure all you need to do is get fenders hood lights and bumper to make it look right
Kevin Fowler wrote:pretty sure all you need to do is get fenders hood lights and bumper to make it look right
The fenders are the same, as stated above the hood, headlights, and front bumper are the only things you need.
Tinkles
v. intr.
   1. To make light metallic sounds, as those of a small bell.
   2. Informal To urinate.
v. tr.
   1. To cause to tinkle.
   2. To signal or call by tinkling.
n.
   1. A light, clear metallic sound or a sound suggestive of it.
   2. An act or instance of tinkling.
*Headlight bracket too....
