Trying to get back into cavaliers. And would use this for my daily.
red 98 cavalier z24. swapped the 2.4 for a 3.5 v6 from a 05 malibu. trans is swapped from a 94 z24. its a nvg 282 wich is one of the strongest fwd manual transmissions gm used. Engine has 30,000 on it and car has 160,000. xtr stage 3 clutch with new slave cylinder, cold air intake, 56mm throttle body, ported intake manifold, aluminum radiator, abs delete, a/c delete, front and rear strut bars, rk sport coilovers on agx struts up front and springs for the the back (not installed yet), custome dash bezel with 3 gauges molded in, b&m short shifter, red back lit gauges, urthane control arm bushings, plastic gas tank (2000+ cavalier).
03 cavalier
american bass 400.1
2x 10" AudioQue HDC3's
Northstar NSB 2400 battery
Kenwood KDC X-993
loudest to date. 147.3 at 45hz
Should be a fun car with that motor in it i would think.
