Cavalier. Is it okay to just use the pinch rails, or is there someplace better to lift it up by?
That's where I lift mine at. I just make sure it is at the point where there are two pinch rails. You will see what I'm talking about when you get on your belly and look under the car.
oil pan
j/k please dont do that.  i use the pinch welds, the rear axle or the rad support
[quote=ßãggéÐÇåv98  (Ûñqùðtäß£è Øñé)] the rear axle or the rad support
Those are also good if you want only one end of the veh up. When I do front brakes I use the Radiator support and the rear axle for back brakes.
I just use the pinch weld spots where gm quotes to place there scissor jack, although when i use a standerd floor jack at those spots..both wheels rise equally per side..hehe i love my coilovers
I gave up on using the pinch welds.  They always fold over and smush.  I usually use one of the places underneath where the suspension bolts up to the body.  It has been a while since I have had to jack up my Z so I can't remember exactly where it is.
Jackass wrote:I gave up on using the pinch welds.  They always fold over and smush.  I usually use one of the places underneath where the suspension bolts up to the body.  It has been a while since I have had to jack up my Z so I can't remember exactly where it is.
I always use pinch welds...but i place something like a small piece of wood on the jack to avoid damage.
"I know not with what weapons World War III
will be fought, but World War IV will be fought
with sticks and stones."
-Albert Einstine-
in the front i use what i read on gm tech service site said...theres a spot on both sides undeer the body it looks like a reinforced metal pads and in the rear i use the pinch welds
MY 2003 SUNFIRE 15.63@87.86mph
"A N/A ecotec is not gonna give Honda's and Mitsu's that much of a run for their
money unless their blown or bottle fed.GM is still smokin crack!"
~1QWKZ24
www.streetracing.org, 08/2001
Ohh3SunFire wrote:in the front i use what i read on gm tech service site said...theres a spot on both sides undeer the body it looks like a reinforced metal pads and in the rear i use the pinch welds
If it's that big square of metal that's part of the unibody, that's where I lift mine by too.  Just behind the front wheel about 3/4 of a foot under the car from the side.
I lift the whole side of my car up from that spot at autox's for tire changes.
I can't stand when the pinc weld bends.  It is not a load bearing point IMO.
-Chris
