how do i realine a door? i am tired of a crushed fender
"Door-to-body alignment adjustments are made by loosening the hinge-to-body bolts or hinge-to-door bolts and moving the door.  Proper body alignment is achieved when the top of the doors are parallel with the fender, the rear door is flush with the rear quarter panel and the bottom of the doors are aligned with the lower rocker panel.  If these goals can't be reached by adjusting the hinge-to-body or hinge-to-door bolts, body alignment shims may have to be purchaced and installed behind the hinges to achieve correct alignment:"
thats straight out of my haynes manual...sounds pretty easy
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
