My car just started running really rich and i want some help fixing it......can anyone help......
Your profile says you just have an intake and exhaust. Your car shouldn't be running rich at all. Maybe it's a problem with one of your gauges? How long has it been doing this?
my gauges are not working its just im blowing black smoke when i take off
umm, why don't you just ask us to find your favorite shirt that you lost in your bedroom?  because with the amount of info you're giving, the difficulty level is about equal with diagnosing your problem at this point.
What gauges do you have?  Check engine light on or no?  Mileage?  Most recent modification?  how soon did problem start after most recent mod?
if you did the exhaust recently, check for any leaks before the O2 sensors... other than that, it could be a bad O2 sensor,  bad tps, an injector thats sticking open, a bad fuel pressure regulator, bad ecu, hell even a bad speed sensor might do it..... the list goes on.  Give us some more info, and we can help you.  Also, are you running a cat?
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
'Nuff said
Ok well i have the intake just put back on the exhaust was done but its catback, i have the air to fuel gauge but i havent hooked it up yet cuz i dont know what wire to tap into for the o2 sensor.  i just hooked up a scanner at my old auto class no codes where found all the injectors were firing the same the two o2 sensors where at the same voltage but the one on the manifold was dropping and then raising.  my air to fuel mixture was at 14.6 so dont know what the hell is going on
ok i still want to hook my a/f gauge up to monitor my air to fuel need some help
god this forum needs the "head banging into wall" emoticon SOOOOOOOOOOOO bad sometimes....
Eco
Turbo
Megasquirt
'Nuff said
Rich Grayo Jr. wrote:i think your turn signal fluid is seeping into your distributor's vacuum port sumehow...
If this doesnt fix it you might want to check your muffler bearings since you just had your exhaust done
lol hate to say it but that problem seems to be common with the 2.4l tc after a while
friends dont let friends roll stock
