so yesterday i got out of work and i had my ac on. i was at a red light and i decided to turn it off then i rolled down my window and the light turned green. i was in 1st gear (reved up at like 4-5rmp) then i switched 2 second and my shifter was loose. i dont know whats wrong with it. its stuck in first gear and i could only swith it to nutreal manually. i cant pop it in reverse and even if i have the shifter in another gear its still in first. i know its not the trany cuz its still drives in first. does any1 know what it might be???? ive heard some1 say that theres a pin on my shifter and all i have 2 do is take out my center console and fix it. is this true or does it sound like something more serious??? thanks in advance guys
Shifter cable either popped off on the shifter assembley, or under the hood. Mine did that and it scared the hell out of me for like, 15 seconds until I relized what had happened.
have you tried clutching?? lololololol
check shift cables
Machzel08 wrote:have you tried clutching?? lololololol
check shift cables
hahah. what a dick. lol jk. i had to clutch to push it back but when i clutch to shift it in another gear it doesnt work. im just stuck on first unless i shift it manually under the hood. i hope its just the cable. i had 2 get it towed to the shop and they wont look at it until monday so they are going 2 call me then.
lets hope just bad linkage
You can shift it manually under the hood, the shifter is loose, sounds like bad linkage to me.
But with all luck involved with automobiles, theres a chance it could be something worse.
think its due to the neon bar in ur grill
I think that's exactly it...
anyways...
my cable popped off at the shifter once, and it also scared the crap out of me...
i know that it's not the issue you're having, but i thought i'd share...
 haha
Jonathan shumacker wrote:think its due to the neon bar in ur grill
 its not a neon they are led lights. similar to the knight rider light. click on my sig and check out my car domain.
well it was a snaped cable only cost 95 2 fix. all is good now thanks guys.
