alright the other day i changed my upper radiator hose cause it had a pin hole in it. after all of that was said and done, i take off to go to the movies. not a mile down the road i start to overheat so i ease back to the house. after checking everything out i discover that my thermostat is failed shut. so i take it out until i can get another one and it does fine except i dont have much of a heater but its not that cold yet. to i go to work and buy a failsafe right and put it in and refill the system. now it overheats again. did my failsafe fail shut or am i missing something?
sounds like water pump time, if thats not upside down.   GOOD LUCk  water pump is a B@@@h
robert seber wrote:sounds like water pump time, if thats not upside down.   GOOD LUCk  water pump is a B@@@h
depends if its a 2.2 or not
found out the problem. i forgot it was a sealed system and i didnt bleed the air out of it. and yes its a 2.2. but im going to try this and hopefully it works
