having problems with 01 z24 2.4 problems with idle and power when you start the car idle really rough and won't stay running give it gas it falls in its face i have replace the whole top cover and plugs, even thought maybe got bad gas so i got all the gas out and put in new stills falls on its face does anyone have answers????????
thanks for the info now
the red z
Are you getting a check engine light?
check eng light is on had it tested mup misfire two cylinders
the red z
compression check buddy....
sounds like a possible spun bearing,
was there damage on the replaced plugs?
LE61T PTE6262 Powered
no damage to the new plugs or old ones car ran fine then all of suddent fell on its face
the red z
maybe check your IAC and MAP sensors
thanks will try that
the red z
alright the iac and map are ok anymore suggestions
the red z
Catalytic converter clogged?
thanks flyinzx11 i did not even think of that
  i will give that a try thanks again for the info
the red z
FlyinZX11 wrote:Catalytic converter clogged?
Funny this came up.  My buddy has a Grand Am that had a near identical problem.  We checked everything.  I never though that a plugged cat would realy do that.  Turned out that was the last thing we checked and sure enoguh that was the problem.  Drilled some holes in it and it runs fine now.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Also check vacuum lines and FPR..  Ive had this problem before lol.
QBE (The Boosted One) wrote:compression check buddy....
huh???
Usually noise with spun bearings, not rough running.
Check the vaccum hose on the map sensor. Also a TPS could do this. Check the vaccum hose first.
just wana to say thanks for all your suggestions i took off the cat and it was full of all the good stuff i just wana say thanks to everyone for leading me in the right direction all i can says in this whole deal least she got a tune up thanks again
the red z
