Does anyone know how to change the head gasket on a 98 sunfire? Is it an easy task to do in a couple of hours? The reason I ask is because I recently changed my spark plugs and I noticed oil on them and the car also has a rough idle, any ideas?
http://registry.gmenthusiast.com/images/jzamarripa/PICT0006.JPG
Oil on the plugs does not directly equal a head gasket leak.  Easiest visual test for a head gasket leak is checking for the presence of coolant in the oil, which will make the oil look like chocolate milk.  If you don't see this, to confirm, have a cylinder compression test run.  If all 4 cylinders are at an acceptable level and equal, it is likely not a head gasket.
1989 Z24 Convertible - Dust Covered
2006 tC - Dust Covered, but driven more
Agreed ... white smoke from the exhaust, rough idle, and I found my oil milky (all tell tale signs). Head gasket! $100 for a gasket set and $70 for new head bolts and not being a mechanic with some good guidance, 3 days and a few beers (lift and tuck technique) Regards, Irv
911 ... got fire?
